Car sometimes won't start, sometimes starts and runs smooth for a while then suddenly tac drops to 0 then back to normal. Seems like maybe it is loosing spark at times. threw a code related to ignition malfuction. Replace the crank position sensor, no change. Fuel pressure was sometimes low so also replaced the fuel pump, still no change.
I have purchased a new ICM for it but can't locate it on the car. I've been looking on the web for info as to the location of this part and I have found conflicting info as to its location including the radiator support, right fender, under dash near steering column and that is doesn't have one at all. The part was listed in the part catalog for the car and I was able to buy one so I am assuming that it does exist on the car but I can not locate it.
Can anyone point me in the right direction here?
