1 - 14 of 14 Posts
Hello Board,
Need some suggestions. This is the situation. After a head gasket failure, I rebuilt the motor in my brother's 89.
During the buildup, it got a windage tray, fresh rings & bearings, block honed and decked, new timing chain, heads ported with factory valves turned down to 7mm, combustion chambers valve relieved and heads shaved to achieve 9.75 to 1 compression, 1.8 roller rockers installed with shorter Comp pushrods, intakes ported, phenolic Intake and TB spacers made by me installed, TB halfshafted and blended, Kirhban regulator installed, MSD wires and coil installed, ASP underdrives installed, 96 Mustang headers jethot coated in place of factory cast manifolds, Flowmaster Force II exhaust.
I cut out the cats and drove it to the exhaust shop after the assembly to have the headers attached to the rest of the exhaust. We fired it up the night before and after a period of crappy idle/sputter the motor smoothened up.
When I drove it to the shop the next morning, it ran ok but would occasionallly stutter and surge while driving and wanted to stall a couple of times while stopped at a light.
With the exhaust on, it ran fine for the rest of the day until I floored it passing a car. As soon as I let of the gas, the car began to surge and stumble and would not run good the whole way home. The next morning, it wouldn't start and I have had no luck getting it running since.
Here is what I have looked at:
1. Spark Plugs- Seem to be very wet after you turn it over, like the gas is not being fired.
2. Ignition- Appears to be giving spark.
3. Checked fuses and links and ECM solenoid.
4. Fuel pressure- Adjusted from 40 - 30 psi with no effect.
5. Tried Changing Coils- No effect.
6. Replaced O2 sensors.
7. Replaced Water Temp Sensor.
8. Replace TFI module.
She will sputter, but will not start. Throw out some ideas guys. I know I must be missing something, but I am drawing a blank.
I tried checking it for codes, but it tells me that all the sensors; MAP, Coolant, TB position, Intake Temp etc. are out of range.
Thanks Dudes.
Branko
Check your ground-- specially the one located at the driver's side motor mount. Next, make sure all of your harnesses are in good shape and that the connectors are all seated well.
My last guess is your fuel pump. Get a pressure gauge and see what it reads.
Welcome to the TCCoA.
PJ
Thanks PJ,
I was a memeber before the crash. Just had to re-register.
All harnesses look good and ground appears intact. I have a railmount pressure gauge and I have tried adjusting the pressure from 30 - 40 psi, no effect.
You say "appears to be giving spark"... no confirmation? If it's firing and has fuel going into the cylinders it's a timing issue. Loose distributor or connection to it? You wouldn't be the first to forget to snug a bolt down on a distributor. I did before you anyway ;)
Doodaa,
I pulled a wire and grounded it. It made spark. I have checked the distributor and even tried rotating it to see if it made a diff. No effect.
The thing that bugs me is that if you turn it over for 10 secs and then pull the plugs, they are soaking wet. I thought for sure that this was a no spark indicator, but when I checked the wires, they had spark.
Hmmm, maybe the timing chain jumped? Not likely I know but you definitely have spark and fuel.... only thing left to get it to run is that they're all there at the same time.... in the proper proportions. Could the EEC have gone bad? It opens the injectors right? ... so probably not... almost has to be something mechanical.
I wondered about the ECM too as it says that all the sensors are bad all at once. I just don't want to cough up huge bucks to find out it is not the problem either.
I really appreciate the help dudes.
Didn't I read a post around here somewhere that someone got an ECU for $1 from the junkyard? Beirutsfinest maybe? I'm old and my memory isn't so good anymore but it's worth a search...
Well today I found a **** load of gas in the oil pan. A backfire must have blown a hole through the intake gasket. I got to pull it apart again.
Intakes are dry on 3.8's fuel must be getting past rings. What would cause the injectors to stick open?
Good news fellow bird lovers. The beast is back. It was the damn TPS. I replaced that piece of **** and she runs like a swiss watch. Thanks to all for the suggestions.
1 - 14 of 14 Posts
