well my issue is:
Car dies in reverse and drive while idling
No check engine light
replaced throttle position sensor
Ideas to solve the issue(according to the part stores):
Egr valve
Idle air control valve
all advice is appreciated
Pull off the idle air control valve and get some carb cleaner or electrical parts cleaner and spray out the insides as you work it open and closed. That should clean out any crap which would be causing it to stick.
The Band, not the Disease!
i had weird idling problems and it died when i put it in reverse and sometimes drive. Turns out it was a loose valve body in the trans. There was even a TSB. How does it idle in park and neutral?
Glad you got it fixed. :thumbsup:
Cheap fixes are the best.
