Ignition Prob...weak/intermittent spark on #4 and #7
This is on a 97 sport. The 4.6 started missing intermittently about 2 weeks ago. It would clear up after running a bit but come back. It got worse. Started pulling wires from the coil and found #4 and #7 with a weak and intermittent spark. Got a friend a the auto parts store so I tried another coil but had the same prob. Spark is weak at idle and goes away above that. Other wires pulled would arc quite a ways before breaking down. Swapped the plug with a good cyl and plugged a new wire in with the same results.
Any ideas would be appreciated.
Thanks
Thanks
