I am just curious if this can be left disconnected? I understand that it may be a safety item so that you cannot put your car into gear accidentally while it is not running but I thought I would ask anyways.
I was going to try to zip tie it and another thought I had was if room permits (I am at work now so the part is not in front of me) was to drill and tap the metal it secures to and drill a hole through the plastic part and see if it can be screwed into place. Like you said zip ties should work fine especially since the cable moves only and not the rest of it.
