on a prior post, someone mentioned that you could pull a gray wire on your maf and it would retard your timing. in relation to a dumb distributor, how many degrees does it retard it and can you do this without a chip.
Overkill Fetish Freak
The octane plug is located near the MAF and used for testing. Unless you "tuner" programs the removal of the "plug" to retard/advacne timing it's best not to mess with it.
-Scott
alright then i guess i wont screw with it, i just wanted to retard the timing to have that cool sounding idle. hmmm....thank you for the warning cause i was about to pull it!
