1 - 1 of 1 Posts
Liz, 4 Cam, and anyone with a DOHC in their MN-12...
If you are using an rpm activated switch to trigger your IMRC opening, where did you pick up the signal or rpm trigger? It’s not like you can wire it to the coil (or should I say coils…)!
Did you get the FRPP adapter for an aftermarket tach?
1 - 1 of 1 Posts
