1 - 20 of 47 Posts
Discussion Starter #1 (Edited by Moderator)
Okay guys I've got this and test fitting with the car on the ground the inner tripod about a 1/4 of it hangs out the inner [yolk] yuck, from reading EECDOC ran his the way I have it set up, but I'm not sure I'm comfortable with it a half inch longer shaft would be nice any thoughts guys?
DSS with stock Tripod
DSS Tripod slid out over clip
Stock with inner clip - DSS only has place for outer clip
DSS 33 Spline Outer
This is it installed; you can see how much hangs out this with wheel hanging
Another shot the upper goes in with wheel on ground
Any pics. I think most of us have never seen the inside of a joint. I'm sure the axles I have are setup the same as Mike did them also and no problems here to 1.52 60'
Send me the pix Rob and I'll post them for you.
Discussion Starter #4 (Edited by Moderator)
I'll send pics when I get back.
My thing is I just dunno how far in the tripod needs to be, also I have no way of keeping the tripod locked out as there isn't a place for an inner ring on the Level 5 axles like the OEM stock ones.
Blown38 are u running the Level 5 axles?
I think mine are cobra inners and axles with the 33 spline outers. I really don't know, Mike would have to chime in.
Or maybe just the inners are cobra.
AED Specialist
Chris has the second set of level 5 axles I built for the MN12 IRS rear. They were originally built for the Black Kenne Bell bird. This was back in the 2005-2006 era.
Pictures are coming
First post updated with pix.
Even with wheel on the ground, the 3 rollors are all about even with about a 1/4 hanging out
Robert
When I pull mine in and out of the car I can feel it moving in and out quite a bit and always afraid it will come apart, but it never has.
Jeez, I'm not so sure how I feel about that. It does look a little sketchy, hanging out like that.
Yea there in no way that's right, we'll if they don't have a longer shaft I can always us a stock axle part, I've got plent and I've got a pair of 01 cobra axles coming and a set of 03 also but there 2 short but extras want hurt for the cobra
So the Cobra axle you were experimenting with when I was down there isn't gonna work?
Discussion Starter #14
Cobra axles are shorter
Well dang. That sucks. I suppose, worse some to worse, you could have a custom axle made.
Discussion Starter #16
Dss rocks there gonna make a custom shaft for the tbird
They rock is all I can say
Robert
Really? Awesome!
I guss you discussed the details with them over the phone?
Discussion Starter #18
And a few pictures and measurements, they had no issue wanting to correct it either, a+++ service
Discussion Starter #20
We are not there gonna make a new shaft that is a cobra shaft there
1 - 20 of 47 Posts
