Ok, I will be running a 125 shot NX kit along with my other mods.
here are the current mods
K&N panel filter (where the real power comes from :D )
March U/D pulleys
180 T-Stat
Motorcraft 12C plugs
Dennis Reinhart chip
02' Stang MAF
4:10 gears
2.5" exhaust - xpipe and no cats and no mufflers
Mark VIII T/C
rebuilt tranny w/ heavy duty parts
HD Transgo shiftkit
I believe that's it
Now the few things to do during the winter to help support the nitrous
255lph fuel pump
throttle body
d/s from Dennis
Big brakes - thanks Joseph :)
Questions are
should I even worry about a throttle body? I know one's off a 02' Stang can be had for real cheap (aren't they 70mm).
Should I get injectors, and if so what size?
I will be getting a reburn from Dennis in the spring (maybe sooner), but I figure I mine as well have everything on to get the best tune possible w/o having to do a reburn soon.
Check with 1MTNCAT he has a lot of racing experience with nitrous.
You may have to go to larger injectors, not sure....but Steve can
give you good scoop on all your intended mods.......he races and wins,
so I'd tend to listen to what he has to say....
Brakes are a great idea. After gettiing new pads and machining the rotors, it only took a couple months till they need to be replaced again :D
What did you go with?
Added that to the list
Mager - my inbox is overflowing with pm's containing advice from Steve and Joel, so I thought I would give them a break :D .
Maybe they will chime in.
