I just ordered my magnaflow dual in dual out muffler. I plan on replacing my third cat with it. I live in NY, will I have any trouble with visual or the readings?
Thanks
Will
Discussion Starter #2
I remember reading that i should pass the readings but just want to make sure, and am completly unsure on the visual. Mustangs have a midbody muffler and its ok will it be for me?
GreenBird said:
Why not wait a week and then be OK for at least a year (or is it two?)
b/c I am up in August
and it is only 1 year:(
I passed no problem with no 3rd cat and a 4 inch exhaust.
No problem at all.
In june NY is going to the OBD2 test, so be sure to shut off all your codes in the computer.
No problem at all.
How would this effect me. I dont really understand you statement. Can you explain it to me please?
Thanks Justin
your 95 the inspection won't change.
For the 96+ cars they are going to a OBD2 test, which means they plug into the system and check it for codes. If you throw a code, then you fail.
But your tuner can turn off most emission related codes in the computer, so it really doesn't matter.
JH
