After installing a Vortech in my 4.6L 96 TBird, I decided to go through with a 3V swap on my 97 TBird sister car. I'm about mid way and using a 2006 Mustang 3V. I'll retain the CDAN4 strategy with a Quarter Horse controller. Therefore, the IAC, coil packs, return type fuel system, slot style MAF sensor and a Navigator throttle body will be used. The two biggest mods are a hole in the hood and the steering shaft must be changed. I went with a steer mod found here on TCCoA. I'm using an off-road head pipe and since my engine is a 2006, I will be retaining the oddball thermostat setup in the lower radiator hose. I'm keeping the PS pump in the lower block position as used on 2V instead of the head mounted 3V version. I'm keeping AC/heat. I should be on the road in a month or so. I'm not doing a video on this like I did for the Vortech but if anyone has questions, I'll be glad to answer them......Ken.
