So what's it take to actually install a cat back exhaust?
My plan is to remove the Y pipe/center cat, and install a true dual with a crossover or a center dual in/out resonator.
I've never installed an exhaust, and I have no welding experience. Is it as simple as using heat/penetrating oil to remove the old exhaust, then bolting up the new one? Anything I need to have on hand to install it? Extra clamps, a few extra connectors, etc?
It looks "easy" assuming I can get the old one off, is it a big deal?
If you're talking about a ready-made kit, it should be pretty easy. I've not purchased a kit before, but cutting/splicing new exhaust tubing isn't too difficult if the system is in decent shape.
If you're talking about a homemade setup, that would be bit more challenging, especially without a lift.
If you have a pre-bent setup, you should be able to cut/splice the tubing with simple hand tools and you can use exhaust clamps to secure the parts together. Otherwise, I don't think bending straight tubes or welding mandrel pieces together would be quite a job!
Yes, I'm looking at ready made kits. Thanks, for some reason I thought it was a much bigger job than that.
There some nice stuff on eBay wallet friendly priced
I did see that. Luckily, when I bought the GT Bird, it already had a true dual exhaust installed with a center mount dual in/out magnaflow and glasspacks on the end of each pipe to give it a mellow yet aggressive tone.
Here is one possible course of action.
http://www.mandrelexhaustsystems.com/servlet/the-Car-Exhaust-cln-Ford-cln-89-dsh-97-Ford-Thunderbird/Categories
https://www.supercoupeperformance.com/2-1-2-high-flow-catalytic-converter-stainless-steel-159
https://www.supercoupeperformance.com/oxygen-sensor-bung-807
https://www.supercoupeperformance.com/stainless-steel-exhaust-x-pipe-
451
https://www.supercoupeperformance.com/x-pipe-resonator-dual-25-inlet-outlet-stainless-material-155
http://www.dynomax.com/mufflers?muffler_inlet_configuration=140
Take parts to an independent garage that specializes in exhaust, and muffler installs. Pick a shop that has an actual tube bender, like a cnc machine, to make fine alignment bends in the mandrel exhaust pipes for proper fitment of various parts listed if needed. And, a quality install means all parts are welded together. No clamps.
451
I like how the O2 bung is a hard to find item lol.
