1 - 13 of 13 Posts
motor city poster
ok well heres the deal... im getting steed u/d's for my birthday later this week..... does anybody have step by step instructions on how to install these things rather quick (if 2 hours is quick for them)? and what tools necessary..... ?? im saying i have 2 hours because that is how long i have to work on my car in my shop at school.... and my teacher said he would let me do it next week.
or do installation instructions come with them... probably different for a t-bird than the typical mustang
any help would be appreciated!
thanks,
Patrick
thanks,
Patrick
Yes... the instructions do come with them, and I would be remiss if I didn't say the obligatory "did you clean your MAF?" .... oh... wrong response for the question... search is your friend. But here is how I did it. Didn't take two hours.
I did mine in 45 mins not bad at all.
Astrophysicist / PostWhore
If you purchased your Steeda Underdrive pulleys brand new, they should come with instructions. If you purchased them used, they most likely will have the instructions, unless the seller stated otherwise.
In any case, you can obtain the install instructions by clicking here.
I hope that helps somehow.
Me and my brother put on a set of the March ones in an hour. We took the fan off the radiator and that gave us enough room to get the impact wrench in there to make busting the bolts off easy without turning the motor. But, don't forget that you will need a puller...that crank pulley did not want to slide off like the others did.
Pete
MaleWhore
are march and steeda pullies the same( i know that steedas are same as ASP.)? also...where can i get a set of U/D pullies for cheap...i searched ebay and they show up for like around 150...im thinking thats the price they kinda go for...thanks
Formerly Fdawg97LX
smoky, $150 is a good price for new steeda's.
red96bird, if you have an impact wrench at your shop you can install the pullies in under an hour.
Frank
motor city poster
yup have 3 (impacts) as a matter of fact...and also the crank pully puller...... so no issues at all!,
thanks for all your help!
motor city poster
one more thing...
smoky....thats where im getting mine from (well my dad is ordering them for my b-day from there)....off of ebay...ill have to let u know how they turn out (or i could even show you because u live somewhat close
Fry Rice Specialist
i'm in michigan too.....:rolleyes:
MaleWhore
that be tight...i live right next to detroit..GP to be exact...midland would be a little far as i understand its west of MI, but troy is doable...
motor city poster
every other weekend im in St. Clair shores...so im about 20 minutes closer if that helps?
right at 10 mile and I-94
steeda's are repackaged ASP's....there on in the same......pulleys shouldnt take long if you dont have trouble with the crank......thats on there crazy tight....but an impact wrench and a crank pulley puller will make that task simple
1 - 13 of 13 Posts
