Nearing the end of all my drive line work.
Saved changing the trac-lok clutches for the end, I've been dreading this task. More so because the friction modifier gives me a headache than anything else.
Anyways, I've heard of people using hose clamps to press the s-spring together, and have heard of some people using a BFH to pound it in. Didn't have any hose clamps and pounding on the unit with a hammer makes me nervous.
This guy's method was very effective for me, it took longer to watch the movie than to actually accomplish the install.
https://youtu.be/O_TqMuV_MeA
<iframe width="420" height="315" src="https://www.youtube.com/embed/O_TqMuV_MeA" frameborder="0" allowfullscreen></iframe>
*EDIT*
My vice grips are bigger than his so I clamped the spring horizontally, where he clamped his vertically. I then put the vice grips kiddie-corner to where he did and then tapped it in.
Hope that makes sense...Wish I had taken a picture :(
*Edit #2*
Just wanted to add, there is no need to remove the the TL unit and ring gear from the case if all you're doing is replacing the clutch packs.
&#775;
Ken's method demonstrated in this video works great..This is how I always install them with a mini pair of needle nose vise-grips..
I've even used this method installing the F-150 "S" Spring..It works good.. :)
Ken is actually a member here..With a great knowledge of all things Ford..I assume from his years of being a Ford service tech..
KENNETHL6
Wow I had no idea, looks like he is still active too.
I was scratching my head trying to figure out something that would work when I decided to check out Youtube. (none of my ideas did)
Thanks Ken! You saved me tons of frustration.
:zbeer: :zbeer: :zbeer: :zbeer:
