so I replaced my Gaskets last night and finally got everything put back together, and went to start the enginne, which started for a half second, then shut off completely. like it was drained. I am willing to believe i connected something wrong somewhere but i have no clue where to look first. Any help is greatly appreicated.
What year and which intake gaskets (upper to lower or lower to heads)? Will the starter crank the engine?
Did you plug the fuel lines back in? Hey, stuff happens...
Go thru each step, and make sure everything is back where it's supposed to be.
If it ran, it's probably NOT the spark. Sounds like no fuel.
Check the inertia shut off. Well I guess the best thing would be to check fuel pressure.
