I am running a Mark VIII engine in my 95 TBird & am using the Bird airbox adapted to the Mark MAF & intake tube. Rather than a panel filter I am running a cone filter inside the fender. The airbox is empty & sealed with weather stripping. This is for stock appearance to satisfy certain state govenment agencies. My question is: does the air flowing from the 3" tube in the fender going into the empty airbox cause any adverse turbulence as it goes into the MAF? I was thinking about fabricating tubing within the box to connect the cone filter to the MAF to get a smoother airflow. Does this make sense or would it be a waste of time?
Thanks in advance for your expert opinions.
Jim
Boost Happy
you should be fine as you axplained it that you are now but you could also do like you said a tube fron the maf to the filter inside the box but if the car is running good and you dont have any problems dont even bother i would just use the panel filter in the box and get rid of the cone .
Jurgen
Do you think they would notice the difference if you went to a different style of factory box? You could possibly use the round cone filter box from a mustang.
Jurgen
:zwthstpd: :tongue:
