shaken, not stirred
I couldn't find a list of all the interior pieces that are interchangeable from a 89-93 bird to my 97 bird. I know that my headliner won't work because its shorter and my moonroof is smaller. and the dashes are different. If everyone could check whether or not these pieces are interchangeable from a 89-93 to a 97 I would appreciate it.
Glove box
Shifter console and surround
Door panels
A-pillars
B-pillars
C-pillars
Rear deck shelf
Air vents
Carpet
Visors (with Moonroof)
Center console
Rear side panels
Anything else you could think i would appreciate it.
C.Hill
Your headliner should be the same size with the exception for the hole made for the moonroof.
The rear decklid should fit, carpet and sun visors.
Everything else you would need to swap over the dash to fit or make work.
The A pillar pieces and rear panels would swap if you installed the auto belts also, then you would need the latch on the seats also.
- Dan
maybe.. you would have to switch the dash too to make it look right. i'm sure theres some cutting and fabbing to be done, but it will work.
