just got the 03 cobra wheels 9 wide from brad and was hoping to go 255x50x17 so the wheel well gap is not so bad. the car is lowered with the ebachs but i dont really want to roll the fender lip. the car is a 97, has this been done? or should i roll the fender lip and go 275s. i'm not to good at body work so how would i do that without making the car look unprofessional? i really want a nice classy agressive stance to it. money is no object. thanks.
CEO, WT Club
Well, if money is no object, take it to a good body shop and have them roll/remove the fenderlip. Then you can run 275's in the rear without issues.
-Joel
Robbie, if money is of no concern then get a match set of 255-45-17/285-40-17 rubber and get the fenders rolled. This is a good size tire in the way of height. It will complete the look. Only thing is that its tough to find a good deal on a match set in that size combination. Choices are limited a bit if you match them in style/brand.
Rolling the fender lip is not going to change the look of the car so don't sweat that.
Brad
Fry Rice Specialist
mine is 17x9 bullit with 36mm offset with 255/50/17
perfect. front have no issue and the rear only rub only when deep bump but i roll the rear fender a little bit inwards and no problem whatsoever.
how do i rolled it? just a piece of steel rod and start bending...
I'm running 255/50s w/ OE 17x8 Bullitts with 30mm offset and Voghtland 1" lowering springs. My shocks are adustable koni's an even on the firmest setting and with the fender lips rolled I get rubbing in front on the passenger side under high speed, high load situations. The rear is fine. I have a pair of the 05+ wheels I'm going to try on the front to see if tucking the wheels in a little helps since the rubbing is on the outside edge.
