1 - 20 of 33 Posts
It seems like it couldn't hurt, if it lowers the fluid temperature, but may be overkill.
Also, would a deeper pan require an extension to lower the filter?
This B&M pan is "moderately priced" at under $200. I've seen some pans selling for close to $400. I'm open to suggestions for other brands.
1994 Cougar XR7 DOHC/5-Speed
No. The stock 96+ pan and filter is the way to go, deepest part of the pan is where the pickup is which is most ideal. The B&M pan is just like the flat pre 96 pans, just deeper and overpriced.
If you want to lower fluid temperature get an actual cooler and do the J mod while your at it(faster fill times = less clutch slip = less heat).
Thanks for the suggestions!
It seems the 1996 style pan doesn't have a drain plug. I assume the 1998 style pan (with drain plug) would also work when using a proper filter.
1998 pan – part # F8UZ-7A194-AA
I've never seen a factory drain plug in any factory 4R70 drain pan. If you can weld, you can easily install one while you have the pan off though.
Ford made 4r70w pans with factory drain plugs for the econoline van for u-haul. They should still be available. I have a LPW deep aluminum pan and enjoy it. Not a stock vehicle. No adverse problem besides cost. Also those gaskets are crap stick the the ford gasket.
With the deeper aftermarket pans - check and see if they add a custom bracket to hold the filter in place to make sure it doesn't fall down.
Having a drain plug would be nice, but not worth $200. I barely spill anything when lowering the pan. Just put a piece of cardboard beneath your oil container. It isn't that hard to balance the pan after you let it hinge down and get most of the fluid out that way.
I would drag a larger pan more often that I just drag the dimple on the 96+ pan. I guess it might be better to have fins to wear off instead one a central area to wear through.
All deeper pans that I have looked at have 3 little legs that hold up the 96+ filter with the tube so that it is held in place.
I drug it all the time on my lowered 97 Cougar, and at least a couple of times with my Mark VIII with a cheapo set of springs replacing the air suspension.
It is usually the very abrupt tall speed bumps, and I also cannot drive either car forward out of my driveway, but backing out is just fine.
I replaced the transmission pan once because in addition to scraping, it hit solid, and it looked like it caved in and creased a corner. My 2000 Grand Marquis hit a curb so hard it broke the filter. That car has a ton of ground clearance compared to the lowered Cougar or the Mark VIII.
Is this correct part number for adding a factory pan with a drain plug to a 1997? or is there some other better number to use?
There is now a new option, Dorman makes a decent stock style pan with a drain. The drain plug is on the other side of the sump, and it is black powder coated.
http://www.dormanproducts.com/p-73883-265-813.aspx
significantly cheaper than the OEM one. F8UZ-7A194-AA is the part number for the "U-Haul" pan with the drain plug. YOU can usually find the Dorman for around 25 bucks, the Ford one tends to run around 60-80 bucks.
Speaking of drain plugs, the O-ring type have always leaked a drop or two for me. Gets the bottom of the pan all dirty. If I were to add them again on a regular pan, I would use an O2 sensor bung and a plug that incorporates a flat copper crush washer.
anyone use the dorman pan. does it fit right and not leak?
is it a lot thinner than the ford one?
Not heard any negatives for it. At the time I was going to use one, I couldn't find one, no one had it in stock, only a few on eBay for the price of the Ford one.
Now the availability is there but I am not really due for a fluid change for awhile, so I haven't ordered one as I don't need more stuff hanging around that I am not yet using.
It is powder coated steel.
1 - 20 of 33 Posts
