With $$$$$ anything is possible.....................
Is it a good idea Sure if ya change the rear end to an 8.8
drive shaft I am not to sure on also need the radiator and a bunch of othe misc things but be prepaired for an involved swap as I have attemted this on before but gave up and just bought a super coupe.....
it will mount up no problem...you need the eec, and harness of course and you do need to the sc radiator...your 7.5 rear should hold up for a little while...try to find a hit sc or cougar xr7 and use everything from that...
