I can go into reverse really really fast and burn rubber but when im in drive it stabs out then when i get to the stop sign and try to stab it again it moves slow and the engine revs up....... Is this a fix that a new transmission screen can take care of?
94cougar4.6 said:
fluid is full. Doesanyonehave a screen on herer for cheap?
What do you mean by transmission screen? Are you asking about a transmission filter? Those aren't expensive at all at your local auto parts store.
Also, I would highly advise against "burning rubber" in reverse.
-Rod
mine would do that too and it was the fluid level i replaced the fluid and got it to the correct fluid level and it works fine now... also you have a 94-95 tranny and those are pretty weak and tend to have a lot of problems... it could just bee your tranny goin out
