1 - 11 of 11 Posts
I was checking out a 70mm T/B on Ebay for the 99-04 Mustang. The seller said that he was planning on useing it on his '96, but it was a different T/B used on the 99-up? How are they different? I thought the 96-04 Throttle bodies were all the same? Will this or won't this work on my '96 Cougar?
I was under the impression that the earlier ones were 65mm and the PI cars used the 70mm T/B. Either way, I'd like to swap mine out to 70mm. Did any year T-bird or Cougar use a 70mm...or am I a tard and have already got a 70mm on my '96 and don't even know it?
Ah, well at least one of us isn't too lazy to use the seach button.:D But It still doesn't tell me if they were all interchangeable from 96-04?
AED Specialist
Mod Motor Cat,
For the AED kit, the 75mm throttle body WILL NOT mate to the inlet adapter. You will need to grind/port some material to properly bolt-on a 75mm throttle body to the AED inlet. A 70mm FRPP throttle body WILL bolt up to the AED kit just fine.
For the positive displacement supercharger (like the AED kit uses) the larger the throttle body, the better. I would go with a BBK 75mm unit.
A-Train
Alrighty then 75mm it is. I'll wait until I pick up the kit to buy the Throttle body. A-train, I can't remember, but does the 6psi AED kit come with 80mm MAF and 30lb injectors like the 9psi, or did they stick with the original FMU? Those are also on my to do list, but if they're included in the kit, why bother, right? I checked out the AED web site and there was no mention of it, but I thought I remeber you telling me they were now included in all kits in an earlier thread?
AED Specialist
Mod Motor Cat,
Your best bet would be to contact AED directly.
AED
A-Train
1 - 11 of 11 Posts
