I went with a 40,000 tranny cooler because i am getitng a 3800 stall tc in about a month.. should this be big enough? thanks!
High-Mileage 4.6L Thrasher
Yep,that's the one I'm using,and here's my input on how to run the lines:
Outlet of the trans to the coolers,then through the 40K GVRW,and then back through the radiator before going back in the return line to the trans.That'll keep the fluid at a nominal operating temp,and will prevent problems with the fluid being too cold.
JL
