Im having a similar problem as aonother guy had on here. I swapped in my 97 mark motor in my 95 bird using my harness and have no spark or injector pulse. Im getting power to both coil packs as well as the injectors but nothing. EDIS looks good, I have the ground strap from the block to the frame rail, checked the main connector, checked the cam and the crank sensor but it does nothing but crank. This is definatly a pain in the ***.
check and make sure that u are getting a good crank and cam signal to the eec,i believe the crank triggers spark and the cam triggers the injector pulse width,are you getting the 2 sec fuel pump burst when u turn the key on ?
I'd start with checking the EEC grounds (pull the EEC connector and verify that each pin that should be run to ground is indeed grounded).
-Rod
You were right racecouger. It was an orange and black wire running to the EDIS module that had to be grounded separatley. Fired right up. Thanks.
