1 - 2 of 2 Posts
I need to know what the correct part numbers are for these two parts, they are from the 1994 T-Bird list linked to at the end of the main control modification tech article if I remember correctly.
2-3 Accumulator F7AZ-7H292-BA
2-3 Spring F7AZ-7F285-AA
I went to check on how much I could get the parts for and they could not find the nubmers listed above leading me to believe they are incorrect in addition to the fact that I rmeember reading that a couple of the numbers were misprinted.
Thanks for your help.
Brad D
Discussion Starter · #2 ·
I found it, sorry for the dupliate post but didn't think the new forum really had enough posts in it yet for this to have been posted but I was wrong. I noticed that the spring doesn't matter because I am not putting it in. The accumulator part number is almost correct, it should end in AB instead of BA, a little FYI in case someone hits this in a search later.
1 - 2 of 2 Posts
