1 - 13 of 13 Posts
I really enjoy my jmodded trans, just as much as the next guy.
However now on a hard launch and the consequent 1-2 shift the car slips out of all gears puts no power down and the engine revs to the heavens.
Im thinking that I might just rebuild it but I dont want to go through all the trouble if it's something smaller.
Car has ~175K on the original trans, fluid is clean and full, J-mod has two springs on the new design 1-2 accumulator and 1 on the 2-3.
Car has ~175K on the original trans, fluid is clean and full, J-mod has one spring on the new design 1-2 accumulator and 2 on the 2-3.
You put 1 spring on the 1-2 accumulator piston and 2 springs on the 2-3 accumulator piston? :confused:
Unless I got it backwards... its been fine for three years its just recently been acting up
Oh, you failed to mention you did the j-mod 3 years ago. Yeh, if you put 1 and 2 springs back in, it had to be 2 springs one 1-2 (one on top, one on bottom), and 1 spring on 2-3 (one on top).
Regardless, back to your original problem. I had that problem when I first did my j-mod except it didn't happen at WOT, but at 1/2 to 3/4 throttle. The car would act like it shifted to 2nd for just an instant, then pop out like it went to neutral. I just kind of ignored it because it didn't happen all the time and it seemed to have went away by itself.
In your case (as I was told could be my problem by some here), the lack of a mechanical diode was known to be weak area in pre-98 transmissions. Sounds like that is your problem, but I'm no expert by any means.
You'll hear from some more experienced here shortly, I'm sure. Good luck!
One way clutch Is gone will it go into the limiter on the 1-2 if u don't let out of it?
Yep Clutch = Gone. With that many miles it might be time for a rebuild.
damn skippy. thats the ticket... Good thing I have a week off coming up soon.
also while i have everyones attention, what brand should I go with for the rebuild kit? and what other parts besides the converter will i need not included in a kit
I use transtar kits, either a new overdrive band or the heavyduty one if it's just a basic rebuild
Robert
Instead of a rebuild i bet you could find a cheap low mile 4R from a junkyard.
I think i can do it my self and just get a $200 kit, I just dont want to pull it or put it back in, but I will to save $1100-$1500. I guess im going to do a marauder converter and mark viii flexplate while its out.
Did you ever get a converter for this? I have one for a Marauder if you are interested.
SWS
1 - 13 of 13 Posts
