I was wondering has anyone tryed jb weld steel to repair loose solder joints on gas tank. I was thinking of doing this when that time comes around. beats the hell out of welding.
NO, welding could cause the fuel to explode anyway!
. . .I know, JB weld.:tongue:
:rolleyes: Welding a empty gas tank is not a safe fix , what I 'd like to know is what is the procedure for a gas tank repair if the lines or should I say fitting become detached from the tank? Some posts say that they must be re-soldered to the tank. I suppose one would use a soldering Iron to complete this repair. But now I am hearing that the fuel tank is plastic, what is the deal.:confused:
After looking at the fuel pump repair how to, on mn12 performance bbs the picture is clear. A fuel pump upgrade is definitly in my future,will solve my phantom gas fume problems of not so long ago. Hence gas tank repaired.:tongue
Thanks, Vancouver BC I will definetly check the vapor canister.
