JDM CNC PI heads with only 500 miles (motor broke the bottom end right after dyno run) I have to install a Timesert into one chamber, decks will be surfaced again. $995 for the pair. They were brand new castings with 8 threads when installed on the motor. These are big dawg PI heads, some nice CNC work here. Only flaw is one spark plug thread was messed up, hence the Timesert.
Heads are complete with 1MM oversized stainless steel valves and TFS springs at 80lb seat pressure. No cams but I would throw in a set of PI cam for free if needed.
