Alright I have a guy who uses 96 and up jmod kits on valve bodies and separator plates. would there be any problem letting him use this on a 95 valve body and plate? Are there differences between the 95 & 96 that would not allow a 95 to be jmoded with 96 up parts? any help would be great thank
the valvebodies are slightly different but many people here have j-modded thier 94-95 tbirds. the j-mod parts are the same so as far as springs acumilators and such. the filter is the only different part i believe along with the valvebody.
contact darrin and ask him about what you want to do.
You should be fine. The 96 pan is for more fluid capacity which also requires the deeper filter. It has nothing to do with the valve body type or year.
