1 - 20 of 28 Posts
Just curious when i do the jmod do i need to replace the 1-2 acc 1-2 spring and the 2-3 acc?? And thats it??
No, that's not it.
You should also drill out the appropriate holes in the separator plate.
This, plus what you posted is what I would consider the minimum for a J-Mod.
Upgrading the servos, and the main valve body are also options to consider.
And, seeing as you have a 94,
You should upgrade to the deep sump pan/filter, from a 1996 or newer, while you are at it. The 94/95 pans can cause fluid starvation under certain conditions.
Mercon V fluid goes without saying, so I won't. You are already using it.
Thanks ya i was just asking if i needed to update those things obviously i was gonna drill the holes :) but thanks for saying it , ya i was gonna get a new pan to i just gotta see how much all this costs. Thanks for respoding rolling thunder
The 96/97 pan and filter should cost around $35-$40 total.
Ok cool. Hey does that one have the drain plug in it?? and also do you have or know anyone that has a better picture of were you have to drill the holes and the new sizes?? I'm just curious because i dont wanna screw it up :)
The 98 pan has the drain plug, and the cost jumps to $75 for the pan.
You can buy a do-it-yourself plug kit for $5 at AutoZone.
The Transmission section of the Tech Articles has pictures of the separator plate, and where to drill the holes.
Ya i know the tech articles has a pic but i was wondering if anyone had a better pic of it sitting up or if some one designed a pic on the computer. Its kinda hard to see the top of it in the pic and i really dont wanna screw up. Oh ya is i cant seem to find the part number of the new 1-2 spring i found everything else 1-2 acc $14.07, 2-3 acc $7.27 98 pan $72.50
Nevermind i found it i'm a dumb** F7AZ-7F284-BA
Give Dan Newman at Joe Cooper Ford a call. He has all the part numbers needed on file. Plus, his price is hard to beat.
F8UZ-7A194-AA - Tranny pan with drain plug.
F6AZ-7A098-A - Filter assembly that goes with deep sump tranny pan
F7AZ-7F251-AA - 1-2 revised accumulator piston.
F75Z-7F284-AA - Light blue spring for top of 1-2 accumulator.
F7AZ-7F284-BA - Bottom spring for 1-2 accumulator (optional - leave spring out for firmer 1-2 shift).
F7AZ-7H292-AB - 2-3 revised accumulator piston
Hey i was curious i was looking at the pic of the transmission parts. I was wondering i see there is one spring on the 1-2 accum piston but weres the other one?? I hope this isnt a dumb question but i'm staring at the picture here but i only see one, and also i'm planning on putting that bottom spring in i dont want the shifts to harsh but will it still make a difference if i put it in?? the pic i'm looking at is
http://www.tccoa.com/articles/tranny/shiftybusiness_files/accum.jpg
Hey guys i just got my parts today i'm gonna do the mod in like 2 weeks. I was curious do you really have to drain the torue converter to do the mod?? I already have merc v in already, i dont wanna drain it if i dont have to and i was also wondering i got the light blue updated spring for the top, i'm just curious does it fit inside the 1-2 acc piston or is it going to be on the outside?? and the last thing i wanted to ask is i'm gonna put a hayden tran cooler on should i use the bottom radiator line to go into the tranny cooler then out to the bottom fitting on the radiator?? meaning cut the line bottom line before it goes to the radiator.
It's not totally necessary, just recommended, to drain the converter. I did one this weekend that I didn't drain the converter, because within the next month, the converter is getting replaced. Yes, the spring goes inside the accumulator, and yes, use the lower tranny cooler line. Most coolers come with an adapter so you don't have to cut the tranny line, screw the adapter into the radiator, and push the hose over the flared end on the line without cutting it.
ok cool thanks rich
Discussion Starter #14 (Edited)
hey i got one more question do any of your recomend a certain store to buy the bits and when you buy them do they have the drill bit # on them and for the .238 hole size what is that in a drill bit size?? sorry if i sound dumb i just dont wanna get this wrong
How long for Jmod you guys. I printed off a set of instructions but will proabbaly print the other of the tech pages for refrence. I am not a mechanic at all but know enough. I got friends who are a lift. how long do you think this would take if I had the right springs, gaskets and the drill bits to get the right holes drilled. This woudl be the time for a tranny coller as well correct?
Regg
On a lift, it took me about 2 hours to do my first one, but now I can knock it out in about an hour, most of the time actually is spent cleaning.
And I found all the drillbits at Atwoods.
reckmann, I too "am not a mechanic at all but know enough". This summer it took me an entire day to do the J-mod and tranny cooler, but I took my sweet time and made sure everything was done right.
I also spent quite a bit of time getting the stuborn tranny line undone from the radiator.
I've heard the mod takes anywhere from 1 hour to 8 hours. My advice is to know the articles like the back of your hand before you actually start.
Good avice, I plan to crawl underneath while my lowering springs go in and takea look at iot. My friend is a mechanic and he knows enough i think two heads put together we could do her no problem. thansk for the help guys I will try to read th eother article in depth too.
Regg
You can read it all day, and it still seems complicated, until you take that Mercon bath, and start turning wrenches, then after it's all over, you'll be like "Man, that was really easy". At least that's what I did:zdunno:
(unless you modify a truck valve body by the instructions, and have the wrong year gaskets, then you'll be wondering WTF for days) Don't ask me how I know!!!!!!!!!
Discussion Starter #20
Hey guys i was curious i see it says to torque the bolts to 90 inch pounds can i convert that to 7.5 foot pounds with a foot pound torque wrench??
1 - 20 of 28 Posts
