1 - 2 of 2 Posts
Yo,
How is everyone doing? I just installed the 2003 PI heads with a port and polish, PI intake, 24 lb injectors, fuel pump and headers.
For some reason i'm smelling raw gas and I can't seem to find a leak anywhere. I also changed my fuel filter but I don't think that this is the problem. It's not the injectors, adj. f/p regulator, or lines under the hood. The smell is very stong when the car is idling and it is coming in through the vents.
Hopefully someone can help me diagnose this problem so my car doesn't blow up.
I also wanted to know if anyone can estimate my brake (flywheel) Hp and give me a rough estimate what time I can run with a set of BFG drag radials (235/60/15) with my list of modifications?
Thunder_281
Amateur Expert
I'm assuming you had the chip flashed for the 24lb injectors? If you can't see fuel leaking, your car might be running rich and unburnt gas is coming from the exhaust. Could be O2 sensors, MAF, etc. Do you have any codes or SES light?
1 - 2 of 2 Posts
