Is this in a SC? If so, the stock fuel injectors are 30lb'ers and they run just fine on the stock SC fuel pump. If this is on a N/A, I'd recommend upgrading the pump to at least a SC fuel pump. Though, if you're going through the trouble of changing the fuel pump, you might as well install a 190 or 255lph pump.
-Rod
