1 - 15 of 15 Posts
I figure instead of making 10 different threads I would make 1 and list all the problems. Hopefully you guys can help me out with most of these.
- Cruise control doesn't work. No light turns on or anything.
- Low Washer fluid light doesn't turn off. I topped off the fluid.
- The rubber part that you put over the spark plug (don't know the name) sometimes popes out and then it runs crappy. Then I have to push it back in.
- Drivers seat doesn't recline back up. It's always leaning way back.
- Passenger side door doesn't lock or unlock, unless you push the lock down forcefully and pull it up with a plires.
- Passenger side window gets stuck about 3/4 the way going up and down.
- When car is in park and idleing the rpms jump from 500 to 100.
- Windshield wipers only work with high beams on and if the blinker is on they stop working untill blinker is shut off.
- There is a dent in the passenger rear panel. It's not one of those easy pop dents. It's creased in more then 1 spot.
I know there is alot there, but if anyone can help out with these I will really appreciate it. Pictures upon request.
Thanks.
Have you had a chance to check the switch at the brake pedal?
Check the connection to the sensor at the base of the reservoir. Could also be a bad sensor.
Get a new set of plugs and wires.
Take off the door panel and spray up the latch mechanism and pivot points with WD-40 or PB B'laster. You may also have to replace the lock actuator and clean the crud out of the lock cylinder too if those are frozen up.
Make sure you're up-to-date on routine maintenance, then clean the MAF and check the TPS and IAC valve.
Sounds like the multifunction switch.
Tap it lightly to unstick the float inside the tank or disconnect the sensor from the tank and the light will be off forever
Take off the plastics or unbolt the seat and I'm willing to be a quarter made its way into the mechanism
Sounds like the factory grease in the locking mechanism is gunked up and frozen solid, you can try degreasing it and re-lubing it but more than likely it will need to be replaced.
If it slows down when its moving to this point then the bushings (buttons) inside of the motor needs to be replaced, ford uses plastic button bushings in their motors which get old hard and brittle and break causing window problems.
Sounds like an IAC issue or a vac leak.
Sounds like a bad multifunction switch.
Body shop.
Thanks for the help so far guys. I'll try all of these things tomorrow and update the thread.
Terminator - I looked at that picture you posted in a different thread showing where that switch is (on the brake pedal) and I can't find it. :\
I'll try to find the schematic in the service manual for you sometime here when I get a chance. It's just kind of hard to get good pics under there in such a tiny space.
On second thought, here's the thread my dad started about the problem we had with the car a year or so ago: http://forums.tccoa.com/showthread.php?t=115111
Update: The low washer fluid light is off now. I just tapped it a few times and it worked.
The rubber part that goes over the spark plug no longer pops out. I just took the plug itself out and put it back in. It was pretty loose. Works fine now.
I looked hard and messed around with alot of things on the brake pedal to fix the cruise, but it's a no go. There is just so many wires and crap under there. It's so confusing compared to my old civic.
Yay! Lol now look for the spare change in the seat mech
Plan on doing that tonight. I've been busy lately. And im trying to save up for tires becuase every day I have to put air in a couple of my bald tires.
:uppoint:
Bwahah!
I have yet to see a car with the seat plastic intact.
Mine was sticking too. A couple of shots of WD40 did the trick for me.
If anyone knows where I can find a set of said seat plastics just let me know, I think they're extinct...
Can anyone please help me out with this cruise control. I need detailed instructions and pictures. I'm new to thunderbirds so I don't know what to look for.
:uppoint:
Bwahah!
They've been in tact on every tbird I've owned including the faded blue sc seats that were in the 95 I bought from Earl.
Can we please keep this on topic. If you can help me with my cruise then I don't care if you post whore in here all day long.
Did you check the cruise control fuse under the drivers side dash?
Discussion Starter #14
Checked all fuses. Tryed to find that switch on the brake pedal stem but I need a detailed picture. There is just so much stuff under the dash I can't find it.
Here's the diagram from the factory service manual that shows the mechanism at the upper end of the brake pedal arm. The switch is labeled #2 in the pic:
<img src="http://img3.imageshack.us/img3/5450/img2402t.jpg" width=600/>
1 - 15 of 15 Posts
