I just bought a 97 cougar 30th Anniversary CHEAP. The old owner went off the road a hit a rock, bending the rim, brakes caliper, the lower control arm and where lower control arm mounts to the k-frame. :(
This why you don't drink and drive. :mad:
The rest of the body is nice and will make a sweet ride. :D I look at all the body line and the body show know sigh of being bent or twisted.
I don't think i find a k-frame from other 30th Anniversary car.
So i know that the brakes are different and some cars had ride control Suspension .
So are all the k-frame the same in all mn-12 cars?
Also want year k-frame would have the same size brakes of the 97 cougar 30th Anniversary ?
Thanks Guy's
Befor you guy ask
I can do the work.
The k-member has nothing to do with the different brakes. I believe all MN-12 k-members are the same. If there is a difference it is the difference in the 89-93 and 94-97 because of the motor mounts.
Brake size doesn't matter...just get a K member from say a 93 and newer (there are some rumors of slightly different motor mounts on the older cars) and you will definitely be fine.
John
