I know most of you think it's a worthless mod (maybe it is, I dont know.) But what is the part # for the 9" one that fits on our cars? I searched but couldnt find a #. Thanks!
http://knfilters.com/
1997 FORD Thunderbird 4.6L V8 F/I - All Automotive FIPK 57-2505-1
57-2505-1 Product Specifications
Product Style: 57 Series FIPK
Type: Gen I
Replacement Filter: RF-1016
CARB EO Number: D-269-12
CARB Exempt: Yes
Weight: 3 lb (1.4 kg)
Product Box Length: 9.19 in (233 mm)
Product Box Width: 9.13 in (232 mm)
Product Box Height: 9.19 in (233 mm)
http://www.kandn.com/images/l/57-2505-1.jpg
just the universal 9in cone that will fit over the stock maf right?
K&N P# RE-0920...i have the box right next to me. it comes with the rubber adapter so it just slaps right one with the hose clamp.
RE-0920 Product Specifications
Product Style: Round Tapered Universal Air Filter
Base Outside Diameter: 6 in (152 mm)
Flange Inside Diameter: 3.5 in (89 mm)
Flange Length: 1.75 in (44 mm)
Flange Type: Centered
Height: 9 in (229 mm)
Top Outside Diameter: 4.625 in (117 mm)
Top Style: Rubber
Top Material/Finish: None
Filter Re-Oiling Amount: 1.92 oz (57 ml)
Flanges: 1
Inner Wire: No
Weight: 2 lb (0.9 kg)
Product Box Length: 11 in (279 mm)
Product Box Width: 6.5 in (165 mm)
Product Box Height: 6.5 in (165 mm)
Also might want to get a heatshield for that filter
-Mike
Your stock intake system takes cold air from the fender well, it most cases people on here say it hurts performance when engine bay air heats up.
I got a cold air intake kit for specifically for a 96 & 97 4.6l cougar or tbird from SCP they also had them for other platforms. This kit was an easy install you remove the air box and other componets. The cone fliter is in the front of the wheel well and the MAF sensoris in the same spot and everything you need comes in the kit took only 15 minutes to install. Took longer to remove the old junk for the car.
