1 - 2 of 2 Posts
I was wondering the k&n part number or model number that would fit to replace where my filter box is, i want to take it out and kinda make it cold air, bit i dont know what k&n filter i should get to attach where the filter box used to be attached.
filter part no.
i bought the k&n cone filter part number re-0920. its nine inches and cost me about 55 bucks from autozone (it was a special order). on my 93 bird i just took out the airbox and panel filter and air silencer and fitted the cone filter on the end of the maf sensor. be careful when you remove maf sensor from the airbox. you will need a hose clamp too. it will probably be a tight fit. i definitely noticed an increase in acceleration, so its a beneficial mod. good luck with it.
1 - 2 of 2 Posts
