Okay, here it goes.. Is there a way to program the key fob to turn headlights on when Unlock is pressed.?
Is there a way to program the key fob to Unlock both doors when hitting button once, Not twice?
thanks
Jason
There is no way to program either of those in, I would guess that maybe somehow you can do all sorts of things with relays and timers.
My 2000 Grand Marquis does (did) the headlights with the auto lamps on and in a situation that they would go on with the key. It still does it sorta with the aftermarket alarm/remote start/Keyless Entry I installed, but only like 10 seconds, not the duration of the delay time. The aftermarket alarms I put in do the unlock all doors at once feature, I liked the two pushes to unlock all on the 4 door, peace of mind for my wife but annoying for me.
It depends on the system that is installed a factory system will give you the basic. But I do know that it can be done with some of the after market system Code Alert w/remote start is one and a good installer.
