1 - 18 of 18 Posts
My Autolock feature stopped working on my Car.. anyone have any insite?..
in the event one does not know what this does.. it is this.. once in the car.. car is started.. and you pass the Gear shifter Past Reverse.. the Doors Lock Automatically.. When I bought the car.. it was disabled.. I reactivated it by putting in the orginal code pressing 7/8 within 5 seconds.. and holding.. then pressing 3/4 within 5 seconds.. letting 3/4 out.. and then letting 7/8 out.. it worked great.. for about a year.. then it stopped..
Reason I did not try again till just now.. is I lost the Master code.. and did not want to take the computer out to get it.. and the previous owner removed the sticker out of the trunk...
Anyway.. I know have the master code again.. (Found the envolope with it written on) and tried to reactivate the Autolock.. with no luck...
Does anyone know why this may have gone out?..
Also one has to be sitting on the drivers seat for this to work.. so I am thinking if anything.. it may be the switch in the drivers seat that is causing this to not work?.. If anyone agrees.. or knows of anything else.. I would greatly appreciate yoru input
Thanks..
Karl :confused:
Dude Check ur fuses. Mine stopped working and I found out the fuse was blown. Replace the fuse and I garantee that it will work. u just have to hunt down which fuse it is.
cougar 3.8
Mine is a 1994
Willow9238
I am o.k. with your reply.. but are assuming that the whole keyless entry system is NOT working.. because everything works fine.. accept the Autolock Feature... I will however track down some fuses
Karl
Thanks everyone for your input.. Hope to hear more
No I'm not. It was just my autolock feature was down all my normal functions worked on the keypad. Unlock Drivers side, passengerside etc. It was just the autolock feature didn't work. I replaced the fuse and it worked again. So yeah go ahead track down the fuses and tell me what happens from there, maybe my car is one of those special cases where doesn't exactly work the way it should, so I could be wrong.
Will
Just wanted to leave an update.. the problem has been found.. the switch in the seat has one of the two wires broken...
I am either going to splice it back together.. or buy another Ford wants about $26.00usd for the Switch..
Thanks for everyones input.. as always it's greatly appreciated..
Karl
save your money and splice it IMO......crimp the connection, or solder it,......cover it in some heat shrink/electric tape and keep the $26 in your pocket for more mods. lol.
I agree with ya... actually.. I just called a friend of mine.. he has a soldering gun.. he is going to loan me so I can give it a try tonite.... if you are interested.. I will post again.. if it worked or not..
Karl
keylees entry autolock
now that is taking care of i have a few problems myself.
for one did'nt ford/mercury come up with the auto-lock feature between 1989-1990?
then my DOOR AJAR light remains on and from what i read from all data it said the switch was located with-in the door jab good new's i found a loose wire but the bad new's is it was'nt for that it was for the light's to turn on when the handle was pulled so where would the switch be and my motorized seat belt dose'nt even work (the pass. side does) but mine's is stuck at the b-pillar and my SEATBELT indicator remain's on and on top fo that the chime module keep's ringing(unless i dissconnect the seat belt module)
Does ur keyless entry system work, if it doesn't check the fuses. if it does. check under ur seat. If that doesn't work maybe u could spray some WD-40 in it and it might come loose.(LOL)but that's the ideas that I have.
Will
seems to me like your door switch may be stuck or broken.......there's a switch that's located behind the door (Where the hinges are) that presses in when you close the door,.......if the switch or wiring is broken/stuck then it's going to think the door is still open (door ajar/chime) and the light is going to stay on ....also,.....if it thinks the door is open,.....the autoseat belts aren't going to work.
I own a 93 T-bird LX. My keyless entry is working fine, but since I bought the car the Autolock function never worked. I didn't know about this, until I saw it on a '93 Cougar LS, about a month ago.
Does t-birds come with autolock too? What seat switch is what you're talking about?
My car is factory equipped with leather interiors and power seats but I haven't seen any unusal or special switch on the driver's seat.
Another question. Do you know if I can get the keyless' remote from a Ford dealer?
Mine is breaking apart.
Thank you.
check the seat switch for sure.
Mine is sensitive enough that if I am not sitting in a certain position it doesn't engage. Then when my weight shifts during a turn, the doors lock.
rm
keyless entry
HEY GREAT NEW'S!!!!!!!!!!!!!!! the keyless entry work's as it turn out i was going for the switch like y'all suggested i should and the connect was put in wrong ( some previous car owner's can be such a dumb a**.)so when went to go to the store i forgot all about the auto-loc feature but when ever i open the door and start the car the system would lock both door's but the seat belt module is part of the fault the driver motor wire's had been cut (hence the dumbass previous owner) he had a front end collision and when he was jerked forward he jammed the guide/track also so when ever he opened/closed the door the motor would run continuosly(or for at least six seconds) so he ut the wire and when those wire's touched the metal it shorted the module out DAMN so now my question is does anyon know how much a seat belt module and guide/track would cost and did ford have like a recall for these type of seatbelt's
1 - 18 of 18 Posts
