Brief and to the point : How do I program two(2) remotes for a keyless entry system on a 93 Cougar XR7? I bought one from a dealership, as mine is a little "worn around the edges" :D , but said dealership can't seem to figure out how to program the remote. Any help is GREATLY appreciated!
Email any ideas to : [email protected]
Pull the covering away on the left side of the trunk to reveal the fuel pump safety shut-off & the keyless entry control box. On the control box is a white connector with two pins inside. Turn your ignition on(do not start) and use a paperclip or similar to short the pins on the connector. The doors will lock & unlock. Then push any button on the remote and the doors will lock. You can program another remote by pushing any button on it after you do the first remote but do both remotes in the same programming session. Turn off the ignition.
