1 - 2 of 2 Posts
Can anyone help me as to how to program a keyless entry remote? Search function was no help at all.
In the trunk (if yours is similar to my 97) there should be a black box behind the carpeting in just ahead of the fuel cutoff switch. Attached to the box is a small two prong connector, about 3/4 the way up on the back side of the box. Turn the ignition to "ON" or "ACC", then short out those two connectors and the door locks will lock, then unlock (which is its way of telling you it's ready for programming). Press a button on your remote (and any other remotes which you want associated with the car) and the locks will lock, then unlock to indicate it has registered the remote. Once you're done, turn the ignition to "OFF" and you should be set.
1 - 2 of 2 Posts
