I ran out of gas in my '97 T-Bird last week. Gauge showed just under a quarter tank and the low fuel light was not on. I could hear the fuel pump turn on with they key on. I had no pressure on the rail, but I did have a little bit of gas as the Schrader valve (not enough pressure though). I figured the pump was bad since it sounded like a wounded duck when it did prime. I changed out the pump (I noticed there was some fuel in the tank, but not very much) and still nothing. I added a few gallons of gas and eventually it primed and got it going. I filled it up and the gauge took a looooooooooooong time to come up to the full mark (like 20 minutes of driving). Now I don't trust the gauge.
Has anybody else had this issue? I see that most people have problems with the anti-slosh module, but that does not appear to be the case given my symptoms. Up until last week it was working perfectly fine. Bad gauge?
Dampened sending unit on new pump, combined with anti-slosh board. Nothing wrong with it taking a few minutes to come up, unless you're expecting to have a ruptured fuel tank.
Possibly. The tank looked fine when I dropped it. I did replace the entire sending unit, pump, and sock (Delphi - made in Mexico, better than China I guess). I also replaced the fuel filter since who knows when it was last changed.
I'll keep an eye on it and the mileage and keep a small container of gas in the trunk. I'm still not sure why it never read empty in the first place though. When it first died it was reading about 1/8 tank and I was on level ground. When I went to the gas station to fill it up I had to pull up an incline to get into the station. Gauge was showing about 1/4 tank and it stalled and wouldn't restart about 15 feet from the pump. Might as well have been a mile. The front passenger corner of the car was the highest point so it took 4 gallons of gas to get to the fuel pump. Finally got it restarted and to the pump and it took a hair over 15 gallons to fill up.
SuperNewbie
1995 Thunderbird LX 4.6 red
Kevin, RalphP mentioned the Anti Slosh module. It's in the guage cluster. They get old.
