On the 94 I just had the oil changed they added fluid and it leaked right out
anyone ever hear of this ??
I have a spare bottle I guess I can swap out when it gets warmer
but its wierd since the low washer light doesnt come on :confused:
I could guess that its burnt out maybe
Mine is leaking also but it isn't the bottle,it is the hard plastic hose coming up from the bottle.Right behind the driver side headlight it is cracked.You may want to check that first.My fix will be to get some rubber hose that fits tight over the plastic line and slide it over it.I have just been too lazy to get out and do it.
Mine is the same exact thing I was wondering how to remove and install the hose and where its routed I found the leak
I just fixed mine a couple weeks ago.the plastic line was snapped where it passes through the fender into the cowl area.I just used about a foot of hose and two clamps all better now. Kinda scratched my head as to why Ford used plastic instead of rubber to begin with.
