1 - 20 of 62 Posts
i know there is info on this in the tech section, but it seems a little outdated. I was wondering what the best way to fix/replace these things were. better to buy new/used? i have a 97 LE if that helps.
thanks,
lee
The best way to fix these is to just buy a new one. You can still get them.
The second best way is to buy a used one from a junkyard, or someone here.
You might be able to test a junkyard unit, by simply plugging it in to your existing harness in the trunk.
The third way would be the cut open and replace LED strip method.
I did that twice, and they lasted for over four years longer.
However, it is a moderate amount of work, and you run the risk of damaging your own housing.
would replacing them with cold cathode tubes work? i would think so, with the right amount of shrouding... then it would be even and wouldnt go out. cheaper than led's...
The inside of the housing is very narrow where the LED strip is mounted- like only 1/2" approx.
If you can get one to fit inside there, I don't see why it wouldn't work.
1/2''? i would fit TWO ccfl tubes in there lol... gues i might order some cheapos when i get new tails, and try this one out. lots of hot glue should make this work. the two ccfl tubees i have under my dash are only about 1/4" wide. and theres a backlight from a laptop i have that is only abuot 1/8".. its in my xbox tho.
hehe.... i could use these... about how wide are the tails?
i'd like to see the cold cathod tubes, it's been idea i've been poking around for a bit. post some pics if you go through with it
hmm. this will be on my 'to do list after i get back from kc.
so i should be fine with a pair of 12" tubes.
i just ordered my 12" bright white cold cathode tubes today. $9.90 shipped. i hope these are what i needed. not sure on the size because it was in millimeters.
Specifications:
Tube diameter: 3.0mm
Tube length: 300mm/100mm
Input voltage of inverter: 12v
Output voltage of inverter: 680v
Current draw: 5.0mAv
Brightness: 28,000~30,000 cd/m?
Lifetime: 30,000 hours
http://cgi.ebay.com/12-DUAL-WHITE-COLD-CATHODE-LIGHT-KIT-MOD-CASE-BRIGHT_W0QQitemZ180106164694QQihZ008QQcategoryZ51064QQrdZ1QQcmdZViewItem
never used these b4 but i'm gonna give it a shot. i have about 3 sets of broken taillights here. and another on my car. I'll try it on the 94-95 style first. i'll post pics by this weekend if they get here in time.
you rule!!! i definitely want to know how it works out... that means that it might look something similar to the marks tails..... *Drool*
any progress? said you got em today! if they look good, i will have a set on order asap
Well i got my cathode tubes today. played around abit. found that there is ABSOLUTELY no way to take that damn lens off. that would make things sooo much easier. well, i burned myself and cut myself twice in the process of the lens removal.
Anyway, the cathodes i ordered were a bit too small. lengthwise that is. and i should have got them in red instead of white. my next try should be pretty damn good. sinhumane will post my pics up here for me. driver side is the cold cathode.
i believe you can get 15 inchers... thats prolly what i will buy.. and in red...
sweet. i took the cathode from the tube it was in and only had to drill a 1/4" hole into the side of the taillight. you have to use the 12v inverter that it comes with. that would have to be mounted in the trunk between the taillights.
<a href="http://www.putfile.com/pic.php?img=5227335"><img src="http://img1.putfile.com/thumb/4/10400371745.jpg" alt="Click to enlarge"></a>
<a href="http://www.putfile.com/pic.php?img=5227334"><img src="http://img1.putfile.com/thumb/4/10400371731.jpg" alt="Click to enlarge"></a>
<a href="http://www.putfile.com/pic.php?img=5227333"><img src="http://img1.putfile.com/thumb/4/10400371643.jpg" alt="Click to enlarge"></a>
<a href="http://www.putfile.com/pic.php?img=5227332"><img src="http://img1.putfile.com/thumb/4/10400371627.jpg" alt="Click to enlarge"></a>
very nice... i like them.. and with some fifteen inchers, these would look super!
1 - 20 of 62 Posts
