1 - 2 of 2 Posts
I have a gremlin in my left brake lamp. Both lamps work with the hazard/signals and the 3rd & right brake lamps comes on when braking except for the left one.
So if the left signal lamp works, means bulbs ok.....which switch or relay should I be looking at for one brake lamp to not work? :confused:
Try swapping the bulb to the side that works and see if the problem follows it. You may just have a bad filament in the bulb. I think these bulbs are multi-filament style. If so, then just replace the bulb.
Jay
1 - 2 of 2 Posts
