I already started a post on V6power.net , but I figured I would let you guys on to what I have going this winter. I ultimately am going to be turbo charged, but I got tired of waiting around to collect all the parts and cost so much, when last year I attained an M112 from a Ford Lightning, and I havent touched it. I figured its been sitting around enough now, and I also get antsy in the winter without being able to drive my baby, so I'm going to stick it on there in the spring. For now, I will be fabricated the intake manifold and piping. It's going to stick up high...I mean HIGH. Like "hot-rod hole through the hood" style high. I've got a spare hood I'll cut a hole in.
I'm going to cut the top off of the SC lower intake and raise it about 2-3/4" and make a flat top surface for the blower, and the inlet plenum will bolt on top of that, which will have to be custom. Myy dry ZEX nitrous and a custom CryO2 setup will keep it all cool on the 1/4mi runs, or when I see certain PSI levels. Here's an example photo I free handed with my sketch pad in PhotoShop:
I originally had planned on it sitting just this high, but the fuel rail did not clear this, so the blower will not have to sit about 1-3/4" higher than these pics show, and it will sit completely above the fuel rail. I may end up getting billet fuel rails to have more clearance and more flexability on where to run the crossover lines and pressure regulator.
Here is the intake, I had today off so I cut it all out. Took quite some time. I'll be going around all the edges, of course, smoothing out around the bolt bosses and bell-mouthing the port inlets some more. The V deflector will also be removed. The mounting bolts to the head will be counter-sunk for more clearance on the walls.
I can only post 10 images per post I guess...
http://members.tccoa.com/thomas/M112onaV6/DSCF0724.jpg
http://members.tccoa.com/thomas/M112onaV6/DSCF0725.jpg
http://members.tccoa.com/thomas/M112onaV6/DSCF0726.jpg
Then I will be mounting a CO2 bottle in the trunk and running an AN line to the engine bay, which will connect a solenoid, and then to the manifold, where it will have a 3/16" brake line coiled in a bunch of "S" shapes on the inside of the manifold, then back out of the intake to a purge where it will vent to the atmosphere. I'll probably aim it at the M112 to keep it cool. This is the same idea as the "CryO2" products, but I'm making it all myself. I will probably run it off of my nitrous RPM switch.
So there it is, a work in progress.
-Thomas
-Thomas
