Does anyone know if there is a way to get the parking lights to flash when you lock the doors with the keyless entry? I was just wondering, because it would be really nice to have a visual signal that my doors are locked. True, the horn does honk when you hit the button a second time, but it can be rather loud at times. Any help or ideas would be great. Thanks
MaleWhore
very good point...mine do...but its only visible on the back...when u hit it 2ice...
if u sit right by the frong of the car ...keep making it beep on the dark..ull see them flash..but the horn goes with them
get a relay
hook up terminals 85 & 30 to +12V (constant) ...you can combine the two wires and fuse it with a 10A fuse .....the +12V constant wire is black/orange underneath the steering column
hook up 86 to the pink/yellow wire in the driver's kick panel....this is the power lock wire that switches to ground upon locking
hook up 87 to the brown wire behind the headlight switch, or you may also look for it at the driver's kick panel
there ya go
