1 - 11 of 11 Posts
What comes stock on tbirds? I have a 93 5.0 and i havent noticed only one of the tires spinning ever. Do birds come from the factory with limited slip? Also, what gears does my car have stock? 3.08?
fords have limited slip
there is a gear decoder in the tech articles, you should be able to read the tag in the inside of the door jamb to read the axle code.
JH
The most common Ford (clutch type) limted slip differential is a Trac-Loc (Traction Lock). "Posi" (Positive Traction) is the Eaton clutch type limited slip differential that comes in most Bow-Tie products.
Eaton DOES make a Positive Traction unit for the 8.8" Ford diff. though. So if you go to a parts store & ask for a "Posi" for an Ford 8.8" diff., you might get what you ASKED for, and Not a Trac-Loc!!!!!
68COUGAR
Aren't Positraction and trac-lok just company trademarks for a limited slip diff?
trac loc is , not sure about posi, a true posi isnt a limited slip .
You GOTTA explain that statement!!!!!!!!
Please explain what YOU think "posi" is? If not short for "Positive Traction", what then? Perhaps you are confusing a Detroit Locker or Spool, with "posi"?
68COUGAR
its been while since i read it , i have to check my book at home. i'll explain tonight.
ok 68cougar, heres the answer , a limited slip is a plate type that acts more like an open diff but holds more driving force to each wheel . . a true positraction unit as are in most gm products are a cone type, when the cones are pressed together , friction allows them to turn as one unit basicly making a locker. and their is a third as well, that uses a viscous clutch . which is smiller in design to a limted slip type, but relies on high viscosity oil to transmit the power. the viscous clutch is also used in most awd transfer cases too . a detroit locker is closer to spool than a posi or limted slip. even though it does have some differentail type gearing, its a basicly locked together type design, which is why its not the greatest if it is in any kind of street car. its more designed for racing and off road applications. hope that clarifies what i meant :)
1 - 11 of 11 Posts
