1 - 10 of 10 Posts
i have the linear logic scan gauge for sale,i bought it off of a fellow member on here,i just dont need it anymore, it Displays 4 gauges at a time from the 12 built-in digital gauges. its not the scan gauge II,it is exactlly the same but just not as thin,it is a great tool to have,you can clear obdII codes,
Fuel Economy
» Fuel Rate
» Battery Voltage
» Coolant Temperature
» Intake Air Temperature
» Engine Speed (RPM)
» Vehicle speed (MPH and KM/H)
» Manifold Pressure
(not available on some vehicles)
» Engine Load
» Throttle Position
» Ignition Timing
» Open/Closed Loop ,thats all the gauges it can check,The units of measure can be changed and the rate of update can be increased or decreased.
TRIP COMPUTER
Automatically tracks four sets of trip data - Each with 11 individually stored parameters.
* Maximum Speed
* Average Speed
* Maximum Coolant Temperature
* Maximum RPM
* Driving Time
* Driving Distance
* Fuel Used
* Trip Fuel Economy
* Distance to Empty
* Time to Empty
* Fuel to Empty
SCAN TOOL
The ScanGaugeII allows you to troubleshoot your own car, read error codes, and the conditions present when the error occurred. You can also turn off the “Check Engine” light and avoid those costly trips to the mechanic.
* Reads Trouble Codes
* Reads conditions that set the Trouble Code
* Clears Trouble Codes
* Turns off the "Check Engine" light
* Tells you when vehicle is "Ready" to pass OBDII testing
* Make and store up to 10 rewritable special codes
to send to the vehicle computer
looking for $100 obo,plus shipping,thanks
Discussion Starter #2
bump.......come on guys,i could really use the money,$65 plus shipping
sounds good,it is a really cool tool to have,just let me know,
These are nice to have. I really like how some people intergrated them into the info center.
sale pending
I may also be interested.
1 - 10 of 10 Posts
