Status
Not open for further replies.
1 - 2 of 2 Posts
Hi,
My 96 TBird has been getting trouble codes P0171 and P0174 (System too lean).
The Long Term Fuel Trim is 25% (very high) at idle. It goes down to zero as the RPMs increase to 1500.
I have replaced the MAF sensor with another used one, and the results are nearly identical.
Question: Is it most likely a vacuum leak causing this, or is there something else I should check?
1 - 2 of 2 Posts
Status
