You might have seen the car in the vid/images forum. The body is a little rough, the interior is great, and the current owner said it has a cracked head. The car was last liscened in 95. I know that I will have to change all fluids, rebuild the whole brake system and maybe a few other things. But I was curious on what other cars I can use the heads off of. I know that all the TC heads will work and that the twin plug cars in the 90's will not, but are there any other cars that will have a compatable head.
BTW, I will most likely rebuild the head using new TC parts.
all will technicly work early heads have d shaped ports
the one you have is a oval port
the dual plug has round ports
you can use the d shaped they can be matched to your intake with a little porting
lightevergreenfrost said:
Any idea on what years , like what the stang used, would they work.
79-86 heads mustang/ranger/fairmont/cougar/t-bird/merkur/etc just make shure the intake ports are the same as the ones on your intake .
non turbo will be fine as well
but i would have some good valves put in it and do some light porting (bowl work),
What else do you need for the car?
I have a bunch of body items that have been in storage for years.
Also 88 suspension parts. All turbo coupe.
No head though.
